What resistor do people use for low speed on universal 80w fans?
Universal fan low speed resistor
- Brianmoooore
That sounds an extremely high value to me!
If the fan input is 80W, it will draw around 7A at full speed, but the absolute maximum current it could draw through a 50 Ohm resistor is around 1/4 A. Sure it's not 5 ohms?
Resistors are rated in Watts, not Amps - no such thing as a 25A resistor. A 50 ohm resistor would only need to be rated at 3W, while a 5 ohm one will need to be around 25W.
Sorry I was talking tosh. Need to stop quoting shoit from memory and start checking stuff. Just checked up wiring diagram and it's 6 Ohms, not 50 Ohms. Makes far more sense. Thanks for correcting me BrianBrianmoooore wrote:That sounds an extremely high value to me!
