WONT rev over 5000rpm full throttle, WILL under partial!!!
rich318i
Tue May 29, 2012 8:54 pm
speed sensor to ECU 100% dont you listen lol
Jibberingloon
Tue May 29, 2012 9:41 pm
Me and wiring = fail!
Please explain.....
I can see the Pin 19 on both are Black / White on the link but what am I suppose to do :(
Where is the. Speed Sensor? And the I can run a direct wire to ECU.
Sorry for being a numpty.
rich318i
Wed May 30, 2012 2:57 pm
sorry its the speed signal not senser
pin9(E30) to pin 20(E36) or pin9(E30) to pin 15 on the ECU (E36) brown/red wire
Jibberingloon
Mon Jun 18, 2012 10:09 am
FYI.............
Problem solved!
New Fuel Pump / Cam Sensor / Block Temp Sensor / Lambda / Proper MAF (Was running a 2.0litre one!)
Only found this all out after putting in a M52 2.8! as there was some fuel starvation issues!
Bollox....
Hey ho, the car goes a lot lot lot better with a 2.8 in it ;)
