Oil level sensor
StevE30
Sun Aug 01, 2010 8:47 pm
Having some troubles with the oil light on the check panel.
I have wired:
M50 / E30
P1 -> P2
P2 -> P10
and the brown wire on the sensor to ground.
the light still stays on.
To check the wiring is it possible to use a resistor across 2 of the pins to make the oil light go out?
StevE30
Sun Aug 01, 2010 10:36 pm
Thanks,
I will try cleaning it tomorrow. If that doesn't work is there a way to bypass the sensor to turn the light out so I can check the wiring is correct
blue30
Sun Aug 01, 2010 11:49 pm
I'd love to know how to shut the check light up too - short of actually installing a sensor obviously :D
