Hello,
i bought an m30 engine which came of an 87 735 auto
now i'd like to know what i would need to do to get the auto harness working.
i'll be using a m10 gearbox + flywheel and clutch (anything else i need?)
i searched alot and nobody seems to get into the auto harness
M30b35 automatic wiring
demelle155
thnx for the detailed answer, so i got some researching to do on the loom and just save myself a few bucks thnx alot
Spigot bearing to fit in the end of the crankshaft, with a bore to match the input shaft of your gearbox.demelle155 wrote: i'll be using a m10 gearbox + flywheel and clutch (anything else i need?)
The engine loom is pretty much self contained, needing only connections to the battery, and an ignition live feed (green) to the loom to body plug for the engine to run. There's also the starter motor signal (black/yellow) and an output to run the fuel pump (green/purple). Everything else is mainly instrumentation or not needed.
