Short Shifter for M30 gearbox
Cypriotgeeza
Post Fri Aug 07, 2015 9:02 pm
Not sure If this has been covered before but I can't find anything on it:
Does the Z3 / Z4 short shifter fit on the M30 gearbox?
Thanks in advance :thumb:
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
jimbom30cab
Tech 1 freak
Post Fri Aug 07, 2015 10:22 pm
Yes the gear shifter will fit if you keep the existing linkage. Personally i preferred standard after trying this though, cheers.
Cypriotgeeza
Post Fri Aug 07, 2015 10:38 pm
jimbom30cab wrote:Yes the gear shifter will fit if you keep the existing linkage. Personally i preferred standard after trying this though, cheers.
Did you? which one did you fit?
I remember fitting one to an E36 (can't remember which one :o: ) and the throw was non-existent and it was notchy as hell! The customer was happy enough with it.. :mad:
gareth
Post Sat Aug 08, 2015 9:06 am
I used a 1.9 Z3 shifter with my M30 (E34 'box) and it was just right.
Bristol_Jer
Post Sat Aug 08, 2015 10:31 am
Same here Gareth, and I renewed all the little bushes as detailed in the wiki guide, that made a nice difference too :)
Cypriotgeeza
Post Sat Aug 08, 2015 12:08 pm
gareth wrote:I used a 1.9 Z3 shifter with my M30 (E34 'box) and it was just right.
Just the info I needed!
I've heard this is the best one to use. 8)
jimbom30cab
Tech 1 freak
Post Sat Aug 08, 2015 3:26 pm
Yer that 1.9 z3 shifter is the one i would use.
Cypriotgeeza
Post Sun Aug 09, 2015 1:04 am
Thanks as always guys!
Now to get some prices lol
Post Tue Aug 18, 2015 9:48 pm
I've got the Z3 shifter on mine too 8)
Cypriotgeeza
Post Wed Aug 19, 2015 12:03 am
ImysE30 wrote:I've got the Z3 shifter on mine too 8)
Which one do you have Imy? And what do you think of it?
Post Thu Aug 20, 2015 8:32 pm
It's the 1.9 one I think. I think it works pretty well, its not too short and feels good :)
Cypriotgeeza
Post Fri Aug 21, 2015 1:35 pm
Is fitting it any different to fitting on a normal 325i or is there anything different that has to be done due to it being an M30?
Bristol_Jer
Post Fri Aug 21, 2015 6:15 pm
No it's the same, only thing is if you are doing it with m30 engine/box in situ then it's a fiddly job! I'd definitely recommend doing all the little bushes and plastic bits at the same time
zaust
Zone day release
Post Sun Aug 23, 2015 6:23 pm
Plus one on z 3 1.9 short shift.
M30 Tech 1 Touring on gas.
Cypriotgeeza
Post Mon Aug 24, 2015 8:53 pm
+ 1 aswell now!
Fitted it along with my LSD and WHAT A DIFFERENCE! :eek: :eek:
1 thing is i didnt have to bend the selector rod at all! it all sat nicely without any modification :? anyone else had this?
Going to update my project thread if anyone is interested :D
Bristol_Jer
Post Tue Aug 25, 2015 7:51 pm
I didn't need to bend mine either, glad you are pleased with it :)
