Need to order a clutch for the anchor and got a good price on a e28 sachs m5 clutch kit, just need to confirm the clutch will work with a m30 single mass flywheel and the getrag g260/5 gearbox?
Does anyone know or has used this combination to confirm?
Ive been reading the m5 clutch will not work on the getrag g260/5 box but all this info was read from a yank site.
All input appreciated and thanks in advance.
Getrag 260/5 and m5 clutch?
BMW_E30vert
Just built mine to the same spec you mentioned !
Single mass,e28 535 Sachs clutch (sprung clutch) and pressure plate
E30 325 clutch slave
Note : I got shorter bolts from main dealer for single mass fly also a shim/ spacer
I pulled part numbers from Realoem.com when searching e28 535i manual
Hope that helps good luck
