wiring guides
midge11
Post Wed Mar 04, 2015 6:33 pm
Right im just about to put my m30b35 engine in and hit a problem .the engines out of a 92 5 series so has the c101 loom on it . My cars a 1984 so has the early loom with the square body connector . Obvs not just a simple fix as the guide . So has anyone tackle this or is there a guide about so I can wire my old loom to the new one
Thank alot mick
jimbom30cab
Tech 1 freak
Post Wed Mar 04, 2015 6:43 pm
I have a guide, PM me your e mail and i will mail it to you
midge11
Post Thu Mar 05, 2015 1:25 pm
Jim your a star that guide has everything you could ever want no about the m30 thanks alot buddy top bloke
Cheers mick
jimbom30cab
Tech 1 freak
Post Thu Mar 05, 2015 1:31 pm
Glad it helped.
e30cbe
Post Thu Mar 26, 2015 8:22 am
midge11 wrote:Jim your a star that guide has everything you could ever want no about the m30 thanks alot buddy top bloke
Cheers mick
:thumb:
mccarthy
Post Fri Jul 24, 2015 11:27 pm
Could I also get a copy of that please?
Black_Op_88
Post Sun Aug 09, 2015 6:51 pm
I've had a problem with my m30 conversion and had to swap out my existing fuse box and loom for another but the c101 plug is different with 14 wires in one and 15 in the other plus they have different screw connections one is a triangle and the other is square. Can someone pm me a walk through on c101's and what needs to be rewired etc?
Billycrx
Post Mon Nov 13, 2017 7:53 pm
Hi mate do you still have the wiring diagram. I'm in middle of a m30b35 swap on my e30 touring and having bother with the wiring side.
sherb
Post Sun Aug 05, 2018 8:19 pm
Thread bump but can I also have a copy of the guide?
