Hi guys i know this is a regular question but through hours of searching i have not found a clear answer to my problem, i want to know if i should fit a manual 3 pin TPS to my m30 engine which has been converted to manual if im running the auto harmess and ecu?
The other thing i have come across is that along with wiring the 3 wires needed to fit the manual tps i came across something about routing a wire back to the ecu, is this neccesary?
any info to help resolve my issue would be greatly aprechiated, thanks.
