m20 exhaust with m30
FMH
Will a m20 scorpion exhaust be ok with m30 conversion or will it be restrictive?
rob0r
I've used a not so good 325i system in the past and my latest conversion is a 325i scorpion, I'm anticipating no problems
- E30 Zone Meets/Events Team
Ideally you want twin 50mm pipes.
jimbom30cab
- Tech 1 freak
yer a scorpion would be quite restrictive in the M30
FMH
Dammmm. Going to miss the le mans tailpipes
leeparkes
I went from a standard 325i system then briefly a 325i scorpion then an E30 M3 scorpion with the twin 50mm piping.
When i went from standard to twin 50mm i seemed to of lost a little low down torque and not any real noticable gains up top.
Imo a 325i system will work fine.
FMH
thanks. le mans will stayleeparkes wrote:I went from a standard 325i system then briefly a 325i scorpion then an E30 M3 scorpion with the twin 50mm piping.
reggid
stockish m30 doesnt need much pipe caus it makes stuff all hp
E30 325is with M20B31
FMH
its not stock/ish.reggid wrote:stockish m30 doesnt need much pipe caus it makes stuff all hp
i'm sure Lee had the alpina b10, so that wasn't stock either
jimbom30cab
- Tech 1 freak
Yer 220bhp out the box is stuff all really.......
FMH
wtf is your problem?jimbom30cab wrote:Yer 220bhp out the box is stuff all really.......
jimbom30cab
- Tech 1 freak
If you read reggit's post he said not to worry about the exhaust pipes as the m30 makes stuff all power anyway
I sarcastically copied that post inferring that 220 bhp is hardly "stuff all"
220bhp for a simple and cheap conversion is pretty good in most people's books
So I dont have any problem thanks
reggid
220 is not alot for the pipes in question, certainly not worth a new system IMO. if it was a 260bhp alpina twin 2" or single 2.75" would be the go
