m30 loom won't fit
pianist
Post Wed Apr 23, 2014 12:03 pm
Hi all
Can anyone tell me if they had trouble feeding m30 ecu plug through the bulkhead? On mine the hole is just too small for the plug! The only thing that i have seen on wiki is that the loom is shorter and ecu needs turning around but nothing about plug not fitting through the bulkhead hole. Btw The plug it self doesn't come apart in the way that it would help with it, so is my only option to cut the hole wider?
Thanks for your help in advance
jimbom30cab
Tech 1 freak
Post Wed Apr 23, 2014 12:34 pm
Sorry I have never seen one not fit, what is the diameter of the hole
got any pics?
m20 loom might fit
pianist
Post Wed Apr 23, 2014 12:44 pm
Don't have m20 loom i'll go measure the hole right now and post it, it is an ex 316 carb chromie, maybe they are different, oh and it is lhd
pianist
Post Wed Apr 23, 2014 12:51 pm
Right, the hole is 45mm diameter if that helps
pianist
Post Wed Apr 23, 2014 1:15 pm
Since we on this topic
where is better place to fit relays that are next to the ecu plug, inside or otside the cabin?
jimbom30cab
Tech 1 freak
Post Wed Apr 23, 2014 2:15 pm
Inside mate, I would largen the hole slightly
pianist
Post Wed Apr 23, 2014 2:23 pm
Yeah thats what I gathered too mate, thanks for advice
