Some before pics -
After -
Guys site is vapourblast.ie for anyone in Ireland looking to get bits done.
Cost me EUR250 or so.jonesy318 wrote:If you don't mind me asking, how much did it cost for the blasting
Haven't done anything to be honest. Had considered a clear coat.Jozi wrote:What do you do to protect the metal and stop it from corroding again?
Any alloy parts i have, even new, have all gotten a layer of oxidation on them over time.
I used ACF 50 and it's good so far, but only could get hold of it on ebayKos wrote:Vapour blasting shouldn't corrode, either way bit of WD40 or another silicone based spray will keep it as new
A product called ACF50 was mentioned to me earlier and is highly rated as well.
The guy who use uses rust inhibitors in the liquid he uses when blastingJozi wrote:Why wouldnt it? Isnt it bare metal?
Igot a new alloy stat housing for my m52 and it looks like shite now, got a layer of white stuff on it, that is corrosion right?
Ive tried dinitrol coroheat and also another product which i think was from raceglaze. Both seemed to prevent this corrosion white stuff but ive only tested it by leaving two coated parts out in the elements.
