m30 out of e30 without load leveller?
shanehaward
Post Sun Dec 29, 2013 5:24 pm
is it possible to lift the m30 engine and box from an e30 without a load leveller?
ive got an e30 with m30 already in but im swapping it into my other shell and don't have a load leveller. Ill be taking it out in the morning and was thinking I could raise the rear of the car and my brother pulls down on the back of the box with abit of rope. Is this possible has anybody else done it this way before?
thanks shane
jimbom30cab
Tech 1 freak
Post Sun Dec 29, 2013 5:29 pm
yer you can do it but I would take off the power steering pp first and the rad of course
just angle it your self manually and take it out millimetre by millimetre
remove the gear linkage of course also and try to angle the back of the car up
get some pics up :D
shanehaward
Post Sun Dec 29, 2013 5:49 pm
thanks jim. I spent half the day stripping it down everything out from the top.. bonnet, rad, loom and disconnected all the hoses etc.. thought I could get away with the powersteering pump but ill take it off in the morning. Just need to take exhaust, prop, and gear linkages which ill do in the morning also then should be out by lunchtime.
Never done an engine swap before so should be interesting. Might start up a build thread
jimbom30cab
Tech 1 freak
Post Sun Dec 29, 2013 10:57 pm
Yer that should be fine, you can pull them out with the PS pump attached but it will touch the front panel (even if the other end is touching the bulkhead) but it is a lot lot easier to take the PS pump off first.
GB Slave cylinder, just take off the 2 nuts.
it's a big heavy beast so take the usual safety precautions !!
With all the bits mentioned taken off I would not bother raising the rear of the car, it will come out fine....up a bit...angle a bit....up a bit....angle a bit.....
Enjoy !!
jimbom30cab
Tech 1 freak
Post Mon Dec 30, 2013 9:59 pm
Got any pics :D
mcbonio
Post Mon Dec 30, 2013 10:27 pm
Yup, pics are always good. The dirtier and filthier the better.! winkeye
shanehaward
Post Mon Dec 30, 2013 10:55 pm
I did take loads yesterday but sat on my phone taking prop off today and smashed the screen. ill take some more pics tomorrow. Ill be taking it out in the morning so ill make sure I take more pictures :)
shanehaward
Post Mon Dec 30, 2013 11:02 pm
did my head in abit because I took them so ide remember where all the hoses and plugs go to. luckily I labelled the wires up and wrote them down and hoses etc should be easy enough to remember.
jimbom30cab
Tech 1 freak
Post Mon Dec 30, 2013 11:08 pm
give me a shout if you need any "completed" pics so I can send some over.
shanehaward
Post Mon Dec 30, 2013 11:18 pm
jimbom you could actually be my hero mate! ill deffinatly give you a shout if/when I get stuck. From what ive done so far its easie than I thought. Think the biggest challenge will be converting it to manual but its all there so ill try my best to remember how it went.
shanehaward
Post Mon Dec 30, 2013 11:22 pm
what shall I do with the shell for the donor? didn't realise how solid it was but does need a new front valance and it does need paint. also got immaculate dark grey/black back comfort interior which I took out the 320i
