Gear box flange removal from m20 box
LadyLeigh
Post Sun Nov 10, 2013 9:44 am
Can someone tell me what size socket I need to remove the gearbox flange from m20 box?
jimbom30cab
Tech 1 freak
Post Sun Nov 10, 2013 9:02 pm
deep thin walled 30mm socket, you can get them from Halfords
might need to pull the flange of with pullers
LadyLeigh
Post Sun Nov 10, 2013 9:46 pm
Ok thank you, is there any special name for the socket as looked in website and couldn't see one, will I also need heat?
jimbom30cab
Tech 1 freak
Post Sun Nov 10, 2013 9:49 pm
No special name
No heat required
Post Sun Nov 10, 2013 11:35 pm
jimbom30cab wrote:No special name
No heat required
Plenty of muscle needed though :mad:
Post Sun Nov 10, 2013 11:56 pm
I have a halfrauds socket for this job, I had to have it machined to fit though
LadyLeigh
Post Mon Nov 11, 2013 2:21 pm
Thank you, managed to get it off, now to put it all back together.
Anyone able to give any advise on the wiring for the m30 conversion?
jimbom30cab
Tech 1 freak
Post Mon Nov 11, 2013 3:40 pm
It's all in the wiki matey but in summary the engine loom is almost identical to the M20 mmotronic 1.3 you just need to swap 2 wires over at the plug and check the all important pin 20 if i re-call correctly - have a look at mine and Lee Parkes build thread and the wiki as its all in there.
leeparkes
Post Mon Nov 11, 2013 5:15 pm
From my thread....
leeparkes wrote:Quick update,
ive done the wiring mod on the loom,
instead of messing with the c101 plug(ie pulling pins out)i cut into the loom
i unravelled some of the tape what covers the loom then picked out the 2 wires (white with black stripe & black with purple stripe),sniped and swaped them over then wrapped it back up with insulation tape.
LadyLeigh
Post Mon Nov 11, 2013 6:20 pm
Thank you lee,
Where the manifold joins the down pipe is hitting the bulk head? How can we resolve this or did yours not do this?
