what flywheel are best suited to the m30b35
mikeyce30
Post Mon Apr 01, 2013 2:50 pm
hello chaps
ive read all the search results and the wiki pages and couldnt find much on this
what flywheel are best used in the m30 b35 i think ive got the dual mass standard from the m30 engine
i have heard that the e28 is the better one as its single mass?
any suggestions
Bristol_Jer
Post Mon Apr 01, 2013 3:25 pm
I think I'm right in saying all m30'd e28s have a single mass flywheel, and the m535 and m5 flywheels are the lightest of the bunch. You will also have to budget for a clutch as the single and dual mass clutches are different, and they're not cheap!
Post Mon Apr 01, 2013 3:41 pm
I have a single mass E28 M535i flywheel should you need one :D
leeparkes
Post Mon Apr 01, 2013 3:42 pm
Any early manual M30 fly will fit, mine is from an E28 525i with an E28 535i clutch.
mikeyce30
Post Mon Apr 01, 2013 8:02 pm
cheers for the info
just been reading your build thread leeparkes thats a great build. did the flywheel make much difference?
i take it you use the flywheel bolts from a e28 then?
leeparkes
Post Mon Apr 01, 2013 9:10 pm
Cheers!
Yes use E28 bolts as there shorter, ive no idea if the flywheel made any difference, i went to single mass fly when the Alpina lump went in.
Post Mon Apr 01, 2013 9:42 pm
You could get a custom E34 flywheel from TTS.
Takes the cheaper E34 clutch kit.
jimbom30cab
Tech 1 freak
Post Mon Apr 01, 2013 9:43 pm
wow, pure porn there Rav
Post Mon Apr 01, 2013 9:47 pm
Thank Jim :o:
But it's just sat in a box atm.
Hopefully, there should be some updates next week. :D
jimbom30cab
Tech 1 freak
Post Mon Apr 01, 2013 9:51 pm
looking forward to them :D
can't wait to see you build come together :D
Post Mon Apr 01, 2013 9:54 pm
leeparkes
Post Mon Apr 01, 2013 11:07 pm
jimbom30cab wrote: can't wait to see you build come together :D
Its taking him long enough. :)
jimbom30cab
Tech 1 freak
Post Mon Apr 01, 2013 11:12 pm
quicker than me, i started stripping down my M30 lump in Jan 2012.
Post Mon Apr 01, 2013 11:14 pm
All good things, and all that :D
leeparkes
Post Mon Apr 01, 2013 11:23 pm
From the first page of my thread, March 09
leeparkes wrote:Got to get a few bits and pieces to get it in but i also want to change a few bits and do the sump gasket,its not leaking now but id rather do it now rather than later
i want it in and running before july
Rav335uk wrote: JULY????????
It should take all of 7 days if everything is there at a push.
:jester:
Come on Rav, chop chop. :)
Post Mon Apr 01, 2013 11:28 pm
Ahhhhh.....
But that's a straight swap, with all the "Polishing" up :D
leeparkes
Post Mon Apr 01, 2013 11:37 pm
Are you saying my first M30 swap was a 'lob in' conversion?
How dare you! :D
Post Mon Apr 01, 2013 11:39 pm
Yep, like mine in the cab :D
leeparkes
Post Mon Apr 01, 2013 11:52 pm
We all know your cab conversion was a 'lob in' swap Rav. :)
We need updates. :cry:
Post Mon Apr 01, 2013 11:58 pm
Soon. :cool:
