As the title sugests my car has developed a misfire above 3000rpm, it ran fine before i parked up then 2 minutes later got back in and it ran like crap.
Ive tried a few things but i need ideas i'm dumbfounded by this, any help will be muchly appreciated!!
Misfire above 3k
mcbonio
I'd be checking your ignition system over, especially the condition of your dizzy cap and rotor arm. Make sure everything is correctly plugged in.
Mike_ERST
I will be checking these during the week, i dont think its a lack of fuel as when i get to 3500rpm it starts popping banging and spitting flames. so im thinking ignition.
i swapped the cps and for the ones from my m20 that didnt change anything so can rule them out.
mcbonio
Sounds like your dizzy cap and rotor arm. I had this same problem when I got my 325i cab, ran fine but missed at high revs, popped like crazy.
I guess if the rotor and dizzy are faulty they can't arc accurately to the correct nodes at high revs.....
Mike_ERST
yeah i'll rip them off tomorrow after work to see if i can spot any problems an probably source new ones. i just cant understand how it ran perfectly fine then 2 minutes later this..
Wocka
Could be just damp in the dizzy cap or leads
Mike_ERST
surely that woud have dried up by now its been like this since before christmas?
mcbonio
Check the resistance of your leads too, they should read about 5-6K ohm, the lead that goes to the coil should be 1-2K ohm.
Mike_ERST
good call i will try those too. thanks for the help guys i really do appreciate you help!
Mike_ERST
took the dizzy cap off last night to have a look seemed ok a tad dirty but ive seen alot worse.
went to take the rotor arm off, undid 2 of the allen bolts and it fell out....that would be my problem then! good news i had a spare basically new one from the old m20 engine so bunged that in and hey presto she runs happily to the limiter again!
mcbonio
Easy fix, good work Mike...!
Mike_ERST
other peoples cars i can give advice on but when it comes to mine my mind goes blank. i did the conversion myself with no help at all except looking things up on here and google. in my head it was a loose wire as it was a sudden change. oh well its fixed now and seems to rev better than ever, first time ive seen a broken rotor arm too!
