Fuel tank breather valve hose question - i'm stuck!!
jimbom30cab
Tech 1 freak
Post Mon Jan 07, 2013 11:38 am
Am having a bit of a brain fu*k working out where this hose below No6 and I’ve put no 284 by it goes
Well, I can’t see where on the throttle body this attaches to, there are no obvious and even not very obvious places for it to go !!
The underside of the throttle body has no connections.
Thanks for any help
Bristol_Jer
Post Mon Jan 07, 2013 6:30 pm
Bottom of inlet manifold I think, although you don't need it. Ditch the carbon cannister, unplug the little valve thing and get rid of that, then the pipe coming from the tank just vent to atmosphere. Then where pipe '289' joins engine side will then need to be blocked off to stop an air leak.
This is exactly what I did with mine, although my pipe '289' was still connected engine side. As I said I'm sure it was under the inlet manifold somewhere, I remember it was quite well hidden but can't remember exactly where it was now sorry!
leeparkes
Post Mon Jan 07, 2013 8:33 pm
As Jer said just bin it.
jimbom30cab
Tech 1 freak
Post Mon Jan 07, 2013 8:42 pm
advice taken and already done,
thanks gents
