Q for Lee P - cooling pipes
jimbom30cab
Tech 1 freak
Post Sat Jan 05, 2013 8:13 pm
Bit of help needed with the cooling system if poss chaps :D
i've taken Lee's advice and used the combined M30 and M20 coolant pipes like below
would i be right in assuming the pipe shown goes to the expansion/header tank ?
if so i was wondering how people have done it
i found this pic on the net which shows a very long pipe run which i've marked in blue but wondered if anyone has just gone a more direct route?
also as i'm converting a M40 car with built in header tank the rad i dont have the tank and pipe shown in yellow above. Are they from an M20 car ??
lastly i have the radiator shown the the above pic and it also has the 2 terminal termostat at the top right of the rad. Is this what you guys use to switch an electric fan ?
thanks very much guys
Jim
Bristol_Jer
Post Sat Jan 05, 2013 8:22 pm
jimboe39540i wrote:Bit of help needed with the cooling system if poss chaps :D
Jim
That pipe will go to the header tank from a facelift m20 engined car as will the small pipe from the top corner of the rad.
If you are using the half m20/half m30 pipes (like I did) then the pipe in blue on your pic doesn't need to be routed that way, it will come from the header tank and join up under the inlet manifold
jimbom30cab
Tech 1 freak
Post Sat Jan 05, 2013 8:29 pm
TOP BLOKE !! Thanks mate, happy with that
i'll get a wanted advert raised for the bits
thanks again.
Bristol_Jer
Post Sat Jan 05, 2013 8:33 pm
No problem :)
Just thought, you might need to make a bracket to fit the m20 tank to your car, as being a 4 pot one I doubt the bracket would be on your car.
jimbom30cab
Tech 1 freak
Post Sat Jan 05, 2013 8:40 pm
yer was thinking that and honestly didn't think for one second of a cable tie bracket.....honest :wink:
Bristol_Jer
Post Sat Jan 05, 2013 9:18 pm
Nothing wrong with a cable tie or 2 winkeye Just think it it as a temporary fix, it will get done 'one day'!
jimbom30cab
Tech 1 freak
Post Mon Jan 07, 2013 9:13 pm
lee, just before i cut the coolant pipes, hope you don't mind me posting a pic of your bay
the inlet manifold bracket i've circled in white
did you route your expansion hose to the left (yellow arrow) or right (blue arrow)
am guessing it was to the yellow arrow side looking at your pics but good to check
ta v much
engine bay looks bl00dy brilliant by the way
mcbonio
Post Tue Jan 08, 2013 10:50 am
:( Wish my engine bay looked like that.... :(
jimbom30cab
Tech 1 freak
Post Tue Jan 08, 2013 11:12 am
it's Lee's bay, yer does look fab
leeparkes
Post Tue Jan 08, 2013 11:20 pm
Tbh i cant remember but i think it came out to the right of the manifold support (blue arrow)
jimbom30cab
Tech 1 freak
Post Tue Jan 08, 2013 11:21 pm
thanks
