How do I bump the starter from the diagnostic port?
mcbonio
How do I bump the starter from the diagnostic port guys?
jimbom30cab
- Tech 1 freak
Remove the valve cover and open the cap on the diagnostic connector. I use a wire with a reverse light switch inline to activate the starter remotely, you can make something similar , or just use a wire to jump the appropriate pins.
The pins you need to jump are numbers 11 and 14. These pins are the same numbers regardless of which type of diagnostic connector you have.
http://www.koalamotorsport.com/tech/art ... valves.asp
not got the wiring diagram with me to check this which i'd recommend
mcbonio
Cheers Jim, I want to do a valve adjust but my socket won't fit between the front of the engine and the radiator and I don't have a ring spanner big enough to turn the engine over.
Thanks chap.
Thanks chap.
