gearbox / prop combo
jimbom30cab
Tech 1 freak
Wed Dec 05, 2012 9:17 pm
Hi, i've read about so many different options i just wanted to check this would work ok.
I currently have an M40 318i cab
would a e34 M30 manual box and a M20B25 prop bolt up nicely. I have the gear selector mechanism from a M20B25 also
dubownerbilco
Wed Dec 05, 2012 9:55 pm
Simple answer, yes :)
Exactly the setup i am using, you have to remove the centre bearing and turn it the opposite wah so that it still bolts to your body in the same place
Also you will need the small output flange from an m20 gearbox to swap onto the m30 box
leeparkes
Wed Dec 05, 2012 10:50 pm
Dont need to mess with the centre bearing it should just bolt straight up.
Flange has to be from a 325i for some reason 320i has different splines and wont fit.
dubownerbilco
Thu Dec 06, 2012 7:56 am
Oh, i read that you needed to reverse the bearing :S, bugger, ahwell it can stay like that :) i cba taking it back off!
Thu Dec 06, 2012 8:12 am
You need to reverse the centre bearing if you're using an E36 328i prop
dubownerbilco
Thu Dec 06, 2012 10:05 am
Ahhhh, my bad :)
jimbom30cab
Tech 1 freak
Thu Dec 06, 2012 4:57 pm
Thanks Gents
Is part No.17 the output flage you are talking about in this M20B25 parts diagram ?
http://realoem.com/bmw/showparts.do?mod ... g=23&fg=15
So take it the job is as simple as removing the M30 output flange and fitting the M20 flange and tighten up the nut.
Many thanks
Jim
leeparkes
Thu Dec 06, 2012 5:02 pm
Yep thats it.
jimbom30cab
Tech 1 freak
Thu Dec 06, 2012 5:11 pm
nice one, cheers Lee mate, now the next challenge is to find one.......
