I know this will be trickier than using a later engine in terms of I will probably have to make the engine mounts rather than buying Lee's. I will also have to blank off the rear waterway as I want the engine as far back as possible. I will probably have to get E34 water pipes too. I bought the engine off a mate who was doing the same engine swap into an E12 m535i so some parts are also E12...
Can I use E12/E28 exhaust manifold and down pipe?
When I did the swap using an E34 M30/E36 rack I still had to seriously re-route one of the downpipes so I will be cutting and welding anyway.
I will also try using the E12 oil cooler and radiator, if anyone has any comments.
