extra plugs on loom?
dubownerbilco
Post Tue Nov 06, 2012 10:31 am
me again :)
i have just been examining the m30 loom before fitting it into the e30 and have noticed the extra plugs and relays that are attatched to the loom near the ecu plug, what shall i do with these?
simply leave them unplugged?
dubownerbilco
Post Tue Nov 06, 2012 12:10 pm
anyone? could do with knowing asap :)
mcbonio
Post Tue Nov 06, 2012 12:16 pm
I'm sure Rav or Lee or one of the other m30 boffins will answer soon.
I'm sure mine are just cable tied up out of the way...
walinsky
Post Tue Nov 06, 2012 1:02 pm
You'll want to keep your relays; they'll come in quite handy for getting your car running.
I cut the extra plugs. They're used on the e34 for switching the cooling fan in the e-box.
leeparkes
Post Tue Nov 06, 2012 2:22 pm
Just leave them unpluged.
dubownerbilco
Post Tue Nov 06, 2012 5:01 pm
ok no probs
am i right in saying the relays are the fuel pump relay and main relay? hence the reason for keeping them...
and aswell, the 3 red wires which also come out near the ecu plug will have to be stripped back along the loom to connect the to battery dummy terminal?
i hate wiring, even the simplest of setups confuses the frig out of me! which is also the reason why my polo has bike carbs, nice and simple :)
mcbonio
Post Tue Nov 06, 2012 5:16 pm
Yeah wiring baffles me too, give me a spanner anyday.! :mad:
dubownerbilco
Post Tue Nov 06, 2012 5:21 pm
i hate wiring so much i would quite happily pay someone to do it for me, and i like to do everything myself normally!
Bristol_Jer
Post Tue Nov 06, 2012 6:29 pm
They are the fuel pump relay and DME relay iirc
dubownerbilco
Post Tue Nov 06, 2012 6:36 pm
just as i thought then :)
k20trew
Post Tue Sep 17, 2013 9:45 pm
Do those red wires you mentioned need stripping back to go to the + battery term.
I hate wiring too :mad:
jimbom30cab
Tech 1 freak
Post Tue Sep 17, 2013 9:59 pm
deleted as it is the wrong picture and was bad advice to the topic
jimbom30cab
Tech 1 freak
Post Tue Sep 17, 2013 10:05 pm
http://www.e30zone.net/modules.php?name ... &start=350
this is the right link now - you can just make out the connections to the +ve terminal
k20trew
Post Tue Sep 17, 2013 10:10 pm
So let me get this clear !
Near ecu plug I have two relays 2 black plugs and one white and a pos.+
*The relays are kept (connected)
*2black 1 white plugs are n/a ( unplugged)
* the pos.+ ----------does this need stripping back past the bulk head bung to be connected to the + on battery
Help me jim sat in front the loom as we speak :mad:
jimbom30cab
Tech 1 freak
Post Tue Sep 17, 2013 10:13 pm
yes I'm pretty sure you are right on all those points
k20trew
Post Tue Sep 17, 2013 10:16 pm
Brilliant thanks mate :cool:
jimbom30cab
Tech 1 freak
Post Tue Sep 17, 2013 10:18 pm
if you get any problems send me note and I will send you my mobile number and I can talk you through what I did, between 6pm and 8pm is best
k20trew
Post Tue Sep 17, 2013 10:42 pm
Legend much appreciated :wink:
walinsky
Post Thu Sep 19, 2013 8:15 pm
k20trew wrote:So let me get this clear !
Yes, yes and yes
