Abit of help from the m30 experts is needed :)
35Touring
Mon Oct 08, 2012 7:29 pm
Just abit of help from the m30 experts needed here....
with the 3 pipes whats the 3rd one... 2 of thhem are fuel lines in and out... is the 3rd a breather ???
Also the heater Hoses there are 2 goin into the car but have no pipes to join these :S
And on the back of the engine there is a pipe goin into the head... ive seen a few 3.5 engines that dont have this .... ????
Bristol_Jer
Mon Oct 08, 2012 7:45 pm
I'm not 100% sure but the pipe on the back of the head means you have an e28 head/ engine?
There is a tank breather hose that tucks into the n/s/f suspension turret on an e30, but that extra one looks like it's had a hose clip on it so possibly was fitted to a charcoal cannister for emmisions?
You need to modify a couple of hoses to get the heater matrix connected up, can't remember off hand which ones but have a look on the m30 fitting guide for what you need to sort it
35Touring
Mon Oct 08, 2012 9:38 pm
ahh yes there was a cannister fitted to the 316 engine must of been for emmisions like you said.. can i just scrap that and leave that out ??....
i was told the engine is e34 :S ill post another pic of engine up see if you no what is...
thanks mate
35Touring
Mon Oct 08, 2012 9:40 pm
leeparkes
Tue Oct 09, 2012 11:41 pm
Bristol_Jer wrote:I'm not 100% sure but the pipe on the back of the head means you have an e28 head/ engine?
im sure these can be blocked off with a plate got from BMW for a couple of quid, Part number 11
http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
then use E34 top rad hose with the matrix pipe coming off it,
The engine looks E34 to me with the later manifolds and by the looks of it running later management, just strange to see the elbow on the back of the head. :? unless as Jer says its an E28 head on an E34 block
There should be a date stamp on the engine block under the inlet manifold somewhere and also one on the head.
Do you know the engine number? (the one just above the starter) if its a later engine the code will start 34 6K b.
Ill double check where those date stamps are tomorrow as ive still got my original M30 stashed away.
Tue Oct 09, 2012 11:47 pm
Early E34 M30's were stamped 35 6K B lee, mine is an 89 build on the head.
leeparkes
Wed Oct 10, 2012 12:01 am
You sure Rav? could of swore mine stamped 34.
Wed Oct 10, 2012 12:08 am
No, i did mean 34 Lee, typo error :mad:
Bristol_Jer
Wed Oct 10, 2012 6:04 pm
Maybe it is an e34 engine that was fitted to a car that needed the elbow, like an e28? Just an idea
And the cannister can be left off, the vent will just go to atmosphere like the earlier cars
leeparkes
Wed Oct 10, 2012 9:18 pm
leeparkes wrote: Ill double check where those date stamps are tomorrow as ive still got my original M30 stashed away.
Date stamp for the head.
Cant find a date stamp on the block but later engine number has 34 6K B under it.
35Touring
Thu Oct 11, 2012 6:28 pm
Cheers for the help lads ill ave a look and see what year the block and head are.... do you no what PAS pumps i could you aswell as my engine didnt cum with 1 and i could do with it as its gonna be for drifting lol....
Another thing Am i ok to buy a 325 exhaust and bolt t up then modifiy the down pipe and mani...
Brad NEarly There
leeparkes
Thu Oct 11, 2012 7:10 pm
You need to use an M30 PAS pump with M20 hoses.
325i exhaust will be fine, the 325i downpipes will slide into the M30 downpipes like this.
Chopped E34 downpipes.
Chopped 325 downpipes.
325 downpipes clamped into the E34 pipes.
They just slide in and clamp up, simple.
35Touring
Thu Oct 11, 2012 8:22 pm
ahh ill have to look out for a pump then... im ok to just run it without PAS for a while ??....
sorry got abit confused there .. so i need e34 535 down pipes onto a 325 exhaust :) thanks for the replys and help Reli appreciate it...
also i have a 325 rad bolted up fits just fine is there any pipes that fit or is it just a cut and make your own pipes up
zaust
Zone day release
Thu Oct 11, 2012 10:04 pm
I Belive I have a pump spare. Will have a look Saturday evening for you and definitely have the blanking plate for the back of the head.
M30 Tech 1 Touring on gas.
35Touring
Thu Oct 11, 2012 10:24 pm
Ohh reli.... thanks mate Top man.... do i have to blank that off then as ive got a pipe goin to it :s....
zaust
Zone day release
Sat Oct 13, 2012 8:12 am
only if you want to remove the pipe.
jimbom30cab
Tech 1 freak
Sat Oct 13, 2012 8:26 am
sorry its a bit off topic but what prop shaft did you use? i'm using an m30 gearbox and the car is currently a 318i cab 1992. i've read the advice and a e36 328i prop seems to be the one recommended. i've found a e36 m3 prop on ebay and wondered if that would fit ?? interested to see what solutions other people have used. thanks :D
Sat Oct 13, 2012 8:34 am
You can use the 328 prop, but I had a custom one made from and E34 front half, and E30 rear.
Leeparkes is running a 325 prop after changing the guibo over on the m30 gearbox to the M20 one.
jimbom30cab
Tech 1 freak
Sat Oct 13, 2012 8:51 am
thannks Rav, i'll ring round and find a 328 prop first.
Sat Oct 13, 2012 9:04 am
Probably easier to swap the guibo round and get a 325 prop :D
jimbom30cab
Tech 1 freak
Sat Oct 13, 2012 11:28 am
ok, sounds good, i'll be needing a M20 325 guibo and prop then !! :D
Bristol_Jer
Sat Oct 13, 2012 6:24 pm
If you can get a 328 prop then it fits straight on, not sure how easy they are to get hold of now as I got mine a couple of years ago
