m30 valve clearances
mcbonio
Post Sat Oct 06, 2012 10:00 pm
Ok so I can't bear the tapping from one of the valves on my m30b35...!!
What are the correct clearances for this engine? I've looked online only to get conflicting info...
Cheers guys.
Post Sat Oct 06, 2012 10:03 pm
The cold clearance , is 0.30mm (0.012 in) and hot clearance is 0.35mm (0.014 in)
the adjustment sequence is (cylinder no) 1-5-3-6-2-4
johnl320
Post Sat Oct 06, 2012 10:09 pm
Definately a valve, not a noisey injector?
mcbonio
Post Sat Oct 06, 2012 10:32 pm
I had thought it might be an injector, but it does quieten down a bit when it warms up.
From my experience, injectors make more of a "clack" sound, this is a "tick"... lol
Bristol_Jer
Post Sun Oct 07, 2012 12:49 am
zaust
Zone day release
Post Sun Oct 07, 2012 6:35 pm
Sure its not The bung fallen out the steering column? Allows noise to travel into the cabin. Also check the exhaust manifold and also where it meets the down pipes as a small leak will give a similar noise.
and if you are going to adjust the tapets make sure they are hot first.
M30 Tech 1 Touring on gas.
mcbonio
Post Sun Oct 07, 2012 8:51 pm
It's deffo a valve on cylinder 6, when I open the oil cap I can see the cam lobe turning / rocker moving in time with the offending tap on the intake side. Is it normal for one valve to just come loose like that?
Was going to have a look at it today but instead rewired my stereo and speakers, fixed my sunroof, fog lights, fitted rear shock mounts and repainted all black trim on the car.. Will have a look tomorrow I think. Trying to get this turd done before cold weather gets here..
Cheers guys.!
mcbonio
Post Sun Oct 14, 2012 5:42 pm
Just of curiosity, I do have a buzz around the column area at low revs. What is this steering column bung thing Zaust mentioned?
leeparkes
Post Sun Oct 14, 2012 6:35 pm
When you take the steering wheel centre cap/horn off you should have a little rubber bung in the end (column is hollow)
Blob of blue tack works fine. :)
mcbonio
Post Sun Oct 14, 2012 7:31 pm
No, there is just the 22mm nut there.! There should be a bung there? Anyone got a photo of this elusive bung?
Just been out to have a look, yeah the column is hollow, didn't realize that was enough to transmit noise. I've plugged it with some blutack.
Great tip lee.!
leeparkes
Post Sun Oct 14, 2012 8:59 pm
:thumb:
mcbonio
Post Tue Jan 15, 2013 11:01 pm
Ok finally getting around to sorting the valve tune up tomorrow,
Quick question;
Do I set the exhaust and intake valves the same ?
leeparkes
Post Tue Jan 15, 2013 11:06 pm
Yes, 0.30mm for both with engine stone cold.
mcbonio
Post Tue Jan 15, 2013 11:36 pm
Is that measurement taken on the valve stem side or the camshaft side?
pianist
Post Tue Jan 15, 2013 11:56 pm
Stem side
mcbonio
Post Wed Jan 16, 2013 7:47 pm
Ok so just did my valve adjustment.....
As a whole the engine feels much smoother to drive and the power delivery is also much smoother.
The valves were pretty tight, too tight to get the 0.30mm feeler in so I had to do them all.
Only thing is it now sounds more 'clacky' than it used to... shall I give it another check over?
Most folks on 'tinternet say .009" (0.23mm) on the cam side is the way to go as the cupping the the stem wear doesn't allow for an accurate reading on the stem side with a feeler... What you all say to that?
zaust
Zone day release
Post Fri Jan 18, 2013 7:28 am
The gaps are correct but I would strongly suggest you only do the cold setting if the cam and rockers are brand new. If not this needs to be done when hot.
mcbonio
Post Fri Jan 18, 2013 9:19 am
My rockers and cams are not brand new, nor do they have any real signs of wear really...
So reset the clearance with 0.30mm hot you say? or 0.35mm hot?
Also how hot is hot? Middle of the gauge running temperature?
zaust
Zone day release
Post Fri Jan 18, 2013 5:39 pm
0.35 and the engine upto normal running temp.
mcbonio
Post Fri Jan 18, 2013 8:58 pm
Cheers Marc.! Will have another bash tomorrow morning. :)
mcbonio
Post Sun Jan 20, 2013 1:16 pm
Ok readjusted at 0.35mm with engine hot. Sounds much better now, no more excessive ticking.
Cheers Marc.!
mcbonio
Post Tue Jan 22, 2013 3:27 pm
Ok so still wasn't happy with the engine tuneup, after driving round a bit the car didn't seem perky at all, and there was lots of ticking still.
I've readjusted them to .011" / 0.25mm from cold. It sounds great, like my m20b25 did which was very sweet. I guess my valve train must have a bit of wear.!
When the engine is cold is sounds great no tapping, smooth. When it's hot I have 1 valve that taps, I can only hear it from inside the car and not outside... Check clearances again when hot?
