m30 gurus needed.!
mcbonio
Post Tue Sep 18, 2012 10:06 am
Need some help from you m30 brains, Ok so I've got my m30 project car, pleased with it but it has running issues.
When cold it starts up fine then idle seeks for a second but stabilizes, but when you touch the throttle the thing chokes up horribly, to the point it sometimes misses a beat for a second then continues to run. It also sounds like a harley davidson at low revs all choked up and stuttering, really not running well.!
Once its warmed up its a little better, but still horrible and difficult to drive, practically stalling the thing as I take off.
Any ideas what I can begin to check?
mcbonio
Post Tue Sep 18, 2012 10:43 am
Been reading the entire m30 thread and have a list of potential suspects...
throttle position sensor
idle control valve
blue temp sensor and wiring
crank sensor wiring
air flow meter
Anyone like to share any thoughts?
MJJ_ZX6RR
Post Tue Sep 18, 2012 1:26 pm
My M30 suffered the same symptoms.
My donor engine came from a catalyst equipped E32 so had a lambda sensor fitted. Unplugging this worked wonders as the car works happily on a default fuel map.
I also had an air leak in the small elbow pipe that runs from the rocker cover to the inlet tract, just before the MAF IIRC. Replacing that elbow helped.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
mcbonio
Post Tue Sep 18, 2012 1:47 pm
Ah good point, I'm not sure which car my M30B35 is from, but I'm pretty sure it doesn't have a lambda sensor fitted. Will double check.
I'm also suspecting low fuel pressure, travelling on the motorway at 70mpg the car was stuttering back like the gas pedal was being blipped. Also it stutters/splutters when you open the throttle hot or cold....
Bristol_Jer
Post Tue Sep 18, 2012 8:01 pm
70 mpg with an m30! :mad: :D
+1 for checking airleaks, mine was an absolute pig to get running properly. An inlet manifold gasket (replaced the lot), a couple of breather hoses and the big AFM pipe on mine all were causing airleaks amongst other things.
Also my fuel filter was ancient, 10 years old I think, so that wasn't helping matters and would be something to check.
If you are ok with a multimeter then you can check crank position sensor, plug leads, blue temp sensor etc for resistance, I found the values by searching on here but can't remember where I found them sorry.
mcbonio
Post Tue Sep 18, 2012 8:32 pm
I mean 70mph.! Doh.! Although you should see my fuel gauge it gets further to the full mark as you go..!
Post Tue Sep 18, 2012 10:15 pm
Check you rotor arm and plugs first, these are the easy ones.
If it's still out, then the crank sensor, leaks in the rubber hoses etc....
DO NOT TOUCH THE AFM yet, if that's origional factory setup, you want to leave it as is.!
mcbonio
Post Wed Sep 19, 2012 8:54 pm
I've checked everything, my m30 is still jerking and spluttering about upon throttle opening...
How can I test the M30 AFM?
Post Wed Sep 19, 2012 9:11 pm
Have you checked the TPS yet??
mcbonio
Post Wed Sep 19, 2012 9:33 pm
Yeah TPS is working fine and calibrated.!
I've checked ICV, working fine. Cleaned out all the air intake system. Idle is good.
Still chokes up bad when you touch the throttle, hot or cold.
zaust
Zone day release
Post Wed Sep 19, 2012 9:50 pm
Sounds like an air leak or faulty cap if all else has been checked.
M30 Tech 1 Touring on gas.
sag
Post Wed Sep 19, 2012 9:52 pm
Have you checked the fuel pipes are the right way around?
mcbonio
Post Wed Sep 19, 2012 10:10 pm
Will check dizzy cap tomorrow, I didn't do this m30 build I purchased it as a running project.
Which 2 fuel lines could get mixed up?
Post Wed Sep 19, 2012 10:11 pm
Check under the inlet manifold, you'll see 2 feul pipes there.
mcbonio
Post Wed Sep 19, 2012 10:13 pm
And during an m30 build these get mixed up? I've suspected fuel delivery as the ride is pretty jerky as if there wasn't a steady supply of fuel. I'll try swapping them around see how it runs.
mcbonio
Post Wed Sep 19, 2012 11:33 pm
Heres a video of it, you really have to rev it to get it stable enough to clutch out and move.
Post Thu Sep 20, 2012 8:31 am
For a start, get rid of the shi77y K&N filter, all your doing is sucking in hot air that side of the engine.
Get the OEM airbox back on, then try.
mcbonio
Post Thu Sep 20, 2012 9:12 am
Yeah it came with that on.! Not a fan of Ken and Norman myself but it still runs like cr@p with the normal airbox on.
mcbonio
Post Thu Sep 20, 2012 8:46 pm
Ok checked dizzy and rotor arm, plugs and leads. All look pretty new.
Tested AFM too, reads 2.5 - 3.5 ohms from closed to open.
Also double checked for air leaks, all is good.
ICV is working, buzzes when ignition is on, valve is free to move.
Replaced blue temp sensor with known working one.
Only thing I can think now is fuel pressure.? What other reason would it choke up when I open the throttle?
Post Thu Sep 20, 2012 8:47 pm
What is the car listed as on the V5?
mcbonio
Post Thu Sep 20, 2012 9:13 pm
Its not been declared yet, still 325i, its also SORN. Why?
Post Thu Sep 20, 2012 9:18 pm
Wondering if it was a 4 pot and not enough fuel coming through via the pump
mcbonio
Post Thu Sep 20, 2012 9:22 pm
Good call, was a 325i though. Thing is it seems fine at mid to high revs, pulls like a train too.
Where is the best place to test fuel pressure? At the fuel rail?
Oh, would a badly leaking centre exhaust box create these running problems? Loss of back pressure perhaps?
Post Thu Sep 20, 2012 9:26 pm
A loss of back pressure wouldn't cause that much of an issue.
Have you have the pot out of the tank???
Maybe some blockage or crap in the bottom of the pot.? :?
mcbonio
Post Thu Sep 20, 2012 9:29 pm
Yeah thats my next port of call, have a look at the fuel delivery system. When travelling in 4th or 5th gear at around 50-7mph, I can feel it shuddering back slightly, as if the fuel supply was being interrupted...
zaust
Zone day release
Post Thu Sep 20, 2012 9:32 pm
No chance of exhaust problem. What year is the engine and what are the last 3 numbers on the ecu ? 179 ? 153 ?
Is the engine earthed correctly? Tps set correctl. There is not much to getting these Lumps running.
Post Thu Sep 20, 2012 9:33 pm
Yes.
Have you changed the FPR on the rail??
I had a problem with mine years ago, changed the FPR and it's been ok after that.
mcbonio
Post Thu Sep 20, 2012 10:33 pm
Good questions guys, its running Zaust just chokes up bad when I open the throttle.
- How can I tell the year of the engine? Where is the serial?
- How can I test the FPR?
Post Thu Sep 20, 2012 10:35 pm
The date of manufacture is on the head, can remeber exactly where though, inlet or exhaust side.
It's large enough to see though enclosed in a circle.
mcbonio
Post Thu Sep 20, 2012 10:42 pm
Ok will have a look, see if it matches up with ECU.
And the FPR, how can I test that?
mcbonio
Post Fri Sep 21, 2012 12:03 pm
Ok the engine has '89 stamped on it and the ECU has 173 on it. Isn't the 173 from the M20 engine?
Bristol_Jer
Post Fri Sep 21, 2012 7:34 pm
Yea, I thought the m30 has a 179 ECU?
Post Fri Sep 21, 2012 8:12 pm
There's 2, 150 and 179 iirc.
Bristol_Jer
Post Fri Sep 21, 2012 8:29 pm
Am I right in saying the 173 ecu can be used if the m30 chip from a 179 is fitted? Maybe the wrong ECU could be the cause of the running problems?
Post Fri Sep 21, 2012 8:54 pm
I have an M20 ECU running my M30 in the Cab, but it has one of Speedtouch's chip in it, and no running issues.
