What accelerator cable do m30 converted cars use?
Just a normal m20 one?
Mine aint the best.
accelerator cable
Bristol_Jer
The one from a 535i e34 iirc. I'll just check though. Got one from Cotswold when I did my conversion
i recon mine is an m20 one then, seems a little tight and has been snapped where the black plastic sheething ends. if that makes sence
do they connect to the e30 pedal and bulkhead ok
Bristol_Jer
Yep straight swap, although getting the plastic grommet from the old cable out of the bulkhead was a pain from memory!
Heres a link to my thread where I ordered the cable and clip from Cotswold, prices and part numbers in there
http://www.e30zone.net/modules.php?name ... ight=cable
Lucky Me
Will get one ordered, will check ecp first
Bristol_Jer
Are you liking the car with the m30 in?
Ummmm will see whats what after a service and new rotor and dissy cap
