advice needed asap please can u help
lee335i
hi i am comin near to the end of my e34 335i engine into my e30, engine is sitting in there i just need a loom, throttle body, gearbox cradel and prop can anyone tell me if the engine loom off a e32 735i auto will fit my engine bearing in mind mines a manual e34 lump coz i have found one but dont want to buy it if it might b wrong, also is the e36 328i prop a straight fit too really want to get it on the road summers comin so anyone knowing of any of the bits i need please contact me asap so i can get this beast on the road cheers hope to speak soon lee
[/b]
Bristol_Jer
Hi Lee,
328i manual prop fitted mine fine, I am using e34 engine + manual box, and Lee Parkes' engine mounts.
Not sure whether you can use the auto loom, but guess with a bit of fiddling with it should be ok. Don't take my word for it though, someone should hopefully be able to give you a definite answer
leeparkes
Auto loom will work and has been done quite a few times on here before, iirc the only difference is the TPS has a round plug instead of square, cant remember if its best to use the auto TPS of graft a square plug to the loom but either way it will work, manual ECU will be fine with it to.
