M30 Custom parts.....
scott320i
Post Thu Feb 02, 2012 1:08 pm
just about finished my conversion....
need to get a windscreen washer bottle.. what have ppl used as im using the std E34 airbox
id like to use a 324TD bottle but i cant put my batt in the boot as the car is a early 320i and dosnt have the space for the batt :(
Cruise control cable... E34 one?
also i am just using the STD aircon fan as the cooling fan (with all the aircon stuff in it) and it runs cool enough ! thats even in peak hour with 41 degrees! and thats on the first stage of the fan
my wireings broke so i havnt had the time to get the high speed on it working.
e21Jason
Post Thu Feb 02, 2012 1:25 pm
Golf mk2 washer bottle in mine
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
scott320i
Post Thu Feb 02, 2012 2:09 pm
oh yeah got a pic?
rob0r
Post Thu Feb 02, 2012 3:06 pm
I used the E34 one from the driver's side. I moved it over as far as I could, then drilled a hole and used a self tapping screw to secure.
e21Jason
Post Thu Feb 02, 2012 5:02 pm
sits in top corner
Z3M Coupe for sale
69 Alfa spyder
zaust
Zone day release
Post Thu Feb 02, 2012 10:40 pm
I use the intense washer bottle (cut away from the main bottle) and mounted it where the m20 afm would sit.
M30 Tech 1 Touring on gas.
Bristol_Jer
Post Thu Feb 02, 2012 10:46 pm
rob0r wrote:I used the E34 one from the driver's side. I moved it over as far as I could, then drilled a hole and used a self tapping screw to secure.
Mine is the same as this
scott320i
Post Fri Feb 03, 2012 3:44 am
yeah sweet thanks for the pics guys!! ill have a look at the wreckers when im there
might have a look to see if i can chuck the batt in the boot.
just dont think the recess is wide enough :(
johnl320
Post Fri Feb 03, 2012 6:20 am
Must a VERY early car if the battery wont go in there. Need pic :D
scott320i
Post Sat Feb 04, 2012 2:11 am
Yeah one of the first e30s it's a 83 320i import from europe maybe uk
I'd post photos but my Internet is playing games an can only get on with the iPhone
scott320i
Post Sun Feb 05, 2012 1:13 am
trying to get the Tacho and economy meter working.... what do the wires in the 3 pin plug under the ECU do?
the black/blue, brown/yellow,and green?.......
and being a Auto motor there are a lot of wires that are not used on the M30 side next to the ECU plug
scott320i
Post Sat Feb 18, 2012 12:31 pm
has anyone got a E34 M30 with cruise? if so can they roughly measure the cable... my M20 E28 one is too long and wrong fittings on the end
