my 335i sport conversion help needed please
lee335i
hi everyone just joined and in need some advice on the conversion. i have a d-reg 4door auto and The g-reg 535i sport that i took the engine and manual gearbox out of had electric throttle and e30 obviously is cable is there an easy way around it if so what? and my engine loom has 2 ecu's do i need both or does one need cutting out or do i need to get a loom with out the electric throttle connection? help needed asap as i work on it nearly every day and am stuck on these few bits
leeparkes
I know someone on here has got rid of the fly by wire but cant remember who.
E30SPORTMAD
a mate used an E32 engine with fly by wire and he says you will need a complete throttle body from a normal 535 engine and all the hoses/pipes to match it, just removed your electric set up and screw the manual on and also you need a manual engine loom as the auto loom is no use to many xtra wires and you only need 1 ECU ending in 179 with the manual loom,also you need the E34 throttle cable and bracket for inlet manifold to hold cable in place, straight forward change over
- E30 Zone Meets/Events Team
White cab ring any bells LEE?leeparkes wrote:I know someone on here has got rid of the fly by wire but cant remember who.
leeparkes
No, im sure he's still running the fly by set up.
Is he, I though he ditched it???
E30SPORTMAD
Think its my mate your thinking on Leeleeparkes wrote:I know someone on here has got rid of the fly by wire but cant remember who.
lee335i
sweet nice one any one know of anyone selling them bits itching to get it in there and fired up
leeparkes
MJJ_ZX6RR
If you are remembering me, yep, still got the fly by wire in mine. Works perfectly, though the 18 months I spent in limphome mode because I had not installed the dashboard EML (BMW's acronym for electronic throttle) warning light was a bit of a wasteleeparkes wrote:No, im sure he's still running the fly by set up.
To the OP, the fly by wire does work well but swapping for the cable throttle version only needs the throttle body, throttle cable, and maybe a couple of small hoses. The 2nd ECU is dedicated to the fly by wire so could be removed if you go cable.
As an aside, EML on on E32/E34 means the car came with traction control. Might be a cool thing to get working in an E30 - I have never bothered on mine. EML also means cruise control is plug and play, and controlled by the ECU and electronic throttle. I do use that a lot in mine.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
lee335i
Thanks guys so think i am going with cable fof throttle and will get another wire loom but can i still keep my old ecu to run it or do i need the one that comes with the loom i get as it will keep costs down if i only have to purchase the loom and can anyone recommend exactly what car to get loom off as i know some have a bigger plug that doesnt fit into e30 plug also does this mean my tc will be on permanent or will this come off when engine is only running 1 ecu and new loom
MJJ_ZX6RR
I believe engine loom and ECU is the same regardless of cable throttle or EML - so don't think there is any need to buy either of these. Have a look through the sticky M30 build thread to see how to wire up the M30 engine loom into the E30 car loom.
TC will be permanently off.
Martin.
Martin.
