what do you use
pjaystar
Post Thu Jul 07, 2011 9:08 pm
please could you be so kind to tell me what you guys think is the best cooling fan to use and a good diff on a stock engine.
also on a stock m30 engine in an e30 what kind of performance could i expected
Bristol_Jer
Post Thu Jul 07, 2011 11:06 pm
What is your car going to be used for? Trackdays, motorway, commuting, bit of everything? Just to help you pick a diff ratio :)
As far as a cooling fan goes, the biggest you can get in the front of the radiator really, I've got a 13" one on mine, as have a few others on here.
leeparkes
Post Thu Jul 07, 2011 11:52 pm
I use an E34/32 aircon fan and it does the job just fine with both M20 and E28 535i rad.
Ive had a 3.64 and a 3.73 on a stock engine, i prefered the 3.64 due to being able to use 1st gear without smoking everywhere. I think a 3.46 would be nice.
In good health they are 211bhp and around 230ftlb but its the big wall of torque that makes these fun, Gareths made around 200ftlb @ 1800rpm.
To give an example of what there like on the road, say your in 3rd gear at just over 1000rpm and you stamp on the accelerator it will start pulling hard straight away, also the power is constant throughout the rev range up to about 5500rpm.
No idea what they would hit 60 in but my arse dyno/rough guessing id say around 6 seconds.
Mine done a 14.5 second quarter mile last year, totally standard M30 3.73 diff in the car in my sig vvv it weighs just over 1300kg.
There's definitely something unsettling about a car that can be doing 2000rpm and still set off like a stabbed cat. :D
pjaystar
Post Sat Jul 09, 2011 8:19 pm
bought the car already converted and using it as a daily run about while my other car is off the road i would like to carry out a few improvements ....it runs alittle hot.. may be a diff... brakes..
what cars have the diffs you have mentioned
thanks
Bristol_Jer
Post Sat Jul 09, 2011 8:24 pm
pjaystar
Post Sun Jul 10, 2011 7:27 pm
thanks bristol
