M30 ECU question
Chrisliney
Post Fri Apr 29, 2011 3:05 pm
hi all
im just about to start my conversion, i seem to have almost all i need as im getting it off a friend off the E30 forum.
my question is that i havent got a ECU for the M30b35. would any M30b35 ecu work or is it a try it and see if it works?
thanks
Chris
leeparkes
Post Fri Apr 29, 2011 3:12 pm
You can use a 172/173 ECU from an M20 320i/325i, the only difference is the eprom chip which can be available from the likes of Speedtouch on here.
Or put a post up in the wanted section for an M30 ECU.
Post Fri Apr 29, 2011 3:14 pm
The proper one is a 179 ECU, as fitted to later 535i/635i/735i models. However, as Lee says, any later 6-pot ECU will work if you fit the correct chip.
The earlier M30B35 used a 150 Motronic 1.1 ECU. A 179 will usually work in its place, at least, it did on my E34 535iSE.
Driftben
Post Fri Apr 29, 2011 4:05 pm
Hi Maurice
Chris is buying my M30, iv still got that megasquirt ecu I brought off you. Would that work when plugged into the standard M30 loom?
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Post Fri Apr 29, 2011 5:57 pm
Not sure, Ben, though I'd imagine you will need to modify the loom somewhat.
When I had it, it was fitted to a 325i Sport (Tech 2). For details on how to fit it, see Flappysocks' site:
http://wiki.diyefi.co.uk/
Post Fri Apr 29, 2011 6:09 pm
I'm running a 325 ECU with one of maurice's chips, works fine.
Chrisliney
Post Fri Apr 29, 2011 6:17 pm
Hi Maurice
I'm just wondering if I can get my hands on a M20b25 ecu, is it just a case of changing the chip and that will enable me to use it for the M30b35 with no other mods apart from the ones made to the loom?
Chris
Chrisliney
Post Fri Apr 29, 2011 9:23 pm
where abouts is the part code that corresponds with the ECU that id be looking for?
thanks
chris
Post Fri Apr 29, 2011 9:55 pm
Hi Chris,
As said above, any later 6-pot ECU will work, so long as you install an M30B35 chip. So you could use an 0 261 200 172/173/380/381.
The label should be on the lid of the ECU. For examples of this, see magpie's recent thread:
http://www.e30zone.net/modules.php?name ... 54&start=0
If you need an M30B35 chip, I can provide either a standard or uprated one.
As regards Loom mods, check out the Sticky guide to it here:
http://www.e30zone.net/modules.php?name ... 93&start=0
Regards,
