Guys,
I have an M90 with a Getrag close ratio box from a 1979 E24 ,
is the conversion any different than the M30 swap?
I have a complete car.
M90 swap
Aussiebilly
wullie325i
- CAUTION - unreliable trader!
theres some numbers i hevant heard in a long time
not sure on the swap but im sure someone will be along to help you out.
welcome to the zone
welcome to the zone
Bristol_Jer
Is it the same engine as in this link?: http://forums.bimmerforums.com/forum/sh ... ?t=1566619
Aussiebilly
Yes, that is the beast.
leeparkes
iirc the M90 is the old M30, does it look like this
Aussiebilly
yes, I assumed the block is the same, just making sure.
- E30 Zone Meets/Events Team
Don't think the block is the same, mounting points are defo different.
Aussiebilly
Rav, Does this make it an issue?
Will it not fit?
Will it not fit?
It will fit, into an e30, but you will have to make custom mounts for the block.
As far as I know, the blocks were changed in the E28
Aussiebilly
thanks Rav,
A lot to think about.
