Diff compatibility
realboss7669
Post Fri Nov 12, 2010 11:59 pm
Hi there,
Does anyone know if an e36 (2003) M3 3.46 ratio LSD (188 casing) would fit my e30? I have an M30 3.5 engine fitted.
leeparkes
Post Sat Nov 13, 2010 12:41 am
Wont be a direct swap, iirc the internals can be swapped into a large case E30 diff though but its not for the faint hearted, give Gareth a pm as he knows how to pull diffs apart
Is it E36 or E46?
realboss7669
Post Sat Nov 13, 2010 1:23 am
leeparkes wrote:Wont be a direct swap, iirc the internals can be swapped into a large case E30 diff though but its not for the faint hearted, give Gareth a pm as he knows how to pull diffs apart
Is it E36 or E46?
Thanks mate, any advice useful on this. Deffo e36 but the chap is definite it is a 188 casing. Will PM Gareth, thanks again. Will probably catch up with you at some point as am blown away and inspired by the stuff you have done on your car!
Cheers bud :cool:
leeparkes
Post Sat Nov 13, 2010 9:00 pm
realboss7669 wrote:Will probably catch up with you at some point as am blown away and inspired by the stuff you have done on your car!
Cheers bud :cool:
Thanks :o: :)
