clutch and flywheel???
redeye
i'm doing an m30 conversion on my 325i and i need to no if the m30 flywheel is the same as any other bmw's?? as i'm finding it a pain to get hold of an m30 flywheel if so what clutch is best to use in this conversion any help is appreciated cheers
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
charlE30
Theo had an E34 M5 fly and clutch for sale that will fit onto the M30, lighter then the E28 single mass aswell
redeye it would be worth dropping him a PM
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
Cypriotgeeza
+1! the original E34 has a dual mass so thicker flywheel --thinner clutch...i found this out the hard way when the person who had my creation before me messed around with the set up!zaust wrote:If you get a e12/e24/e28 fly make sure you get a matching clutch, they are all single mass. If you can find a e32 manual then it will be the same as the e34 heavy twice the mass one.
hth
http://www.e30zone.net/modules.php?name ... c&t=172482
most info you'll ever need about the m30 clutch setup is there l o l
good luck with it
