radiator
k20trew
Post Tue Jun 22, 2010 4:50 pm
could somone confirm that a e24 635csi rad is the same as a e28 535i thanks in advance guys winkeye
charlE30
Post Tue Jun 22, 2010 6:53 pm
According to my BMW ETK they are the same radiator :thumb:
HTH
Charlie
BMW F31 335d xdrive
k20trew
Post Tue Jun 22, 2010 11:00 pm
thanks charlie
i was given one today [for free] and was told they were the same "RESULT" :D
Post Tue Jun 22, 2010 11:01 pm
Lucky bugger, very rare to find now :D
Luca318is
Post Mon Aug 30, 2010 3:21 pm
anyone knows if an e46 radiator fits? according on the measures i found on ebay, it's nearly the same dimensions of the 535i one, but it cost a half here in italy!
charlE30
Post Mon Aug 30, 2010 7:42 pm
Luca318is wrote:anyone knows if an e46 radiator fits? according on the measures i found on ebay, it's nearly the same dimensions of the 535i one, but it cost a half here in italy!
As long as it fit's between the chassis rails anything can be made to fit :D What position do you have your engine in (assuming it's an M30) I've run a standard M20B25 rad and now a standard E34 535 rad with my engine in position 3 (furthest back)
Charlie
BMW F31 335d xdrive
leeparkes
Post Mon Aug 30, 2010 10:54 pm
What is the E46 rad off?
E46 will have the expansion tank on the side of the rad though, dont know if it will be an issue.
I too ran an M20 rad for a while and didnt have any 'shityourself' moments at all, although the fan is on a lot :D
Luca318is
Post Tue Aug 31, 2010 3:20 pm
the e46 radiators are all the same from 316i to 330i! they are the same size of the 535i e28 one! i have already a e36 318is radiator but it's very little, my m20b20 radiator is pre restyling and it's really tiny!
but you're right i didn't thought about the expansion tank... where must it be plugged using the e28 radiator?
oh i have the engine in pos2, the e36 radiator fits well
Luca318is
Post Wed Sep 01, 2010 10:48 am
ok no problem guys, thanks anyway i probably find a used e24 radiator!
