Prop for M30
Baurluvva
Hi all,
I have read that the e36 328i manual propshaft fits the m30 conversion....... I have been told that the 323i e36 prop is the same length..... but is the 325i e36 manual prop?
Does anyone know or can point me in the right direction???
leeparkes
Ive heard the 328i prop fits by reversing the centre bearing
Im still using the 325i prop as its the perfect length, some say its not strong enough but 12 months on and miles of 'hard' driving its still holding out fine,
the M20 turbo boys have put 300+bhp through them with no horror stories, plus there readily available
iirc the prop length should be 1495mm (but dont quote me on that)
- E30 Zone Meets/Events Team
leeparkes wrote: iirc the prop length should be 1495mm (but dont quote me on that)
You're right on there Lee with the length of the prop mate.
leeparkes
I surprise myself sometimesRav335uk wrote:You're right on there Lee with the length of the prop mate.leeparkes wrote: iirc the prop length should be 1495mm (but dont quote me on that)
Baurluvva
Cheers guys!
Just need to get hold of an e30 325 prop as the 316 donor wont cut it!
Baurluvva
Will I have to change gearbox flange or is it bolt on?
leeparkes
Yep, to use a 325i prop you will need to use the flange off the 325i box
leeparkes
Is the M30 going in the baur in your sig?
Baurluvva
No - that has one already!!
5 stud running gear
M3 lsd, prop, exhaust
Just a few bits of welding to complete then its all good!!
I just bought a 316 auto touring and have a spare m30 and box knocking around
5 stud running gear
Baurluvva
Excuse my ignorance ....... but how easy is it to do the flange swap???
leeparkes
Ah, i see, i nearly brought a baur a few years ago till i pulled the carpets back in the boot, cool E30's, i like them
The flange is held on by a 30mm nut, you will need a deep socket (has to be fairly slim too) once the nuts off it just slides off the shaft.
Baurluvva
Baurluvva
Will a 2.0 gearbox flange be the same? I have a spare 2.0 box!!
leeparkes
No it must be off a 325i because for some reason the splines dont match with a 2.0 boxBaurluvva wrote:Will a 2.0 gearbox flange be the same? I have a spare 2.0 box!!
charlE30
Ah I remeber the day when I did my conversion and there was only a few of us 335's kicking about, prop options back them where E30 M3 or custom. I just love the way it's all moved forward with more people trying different parts from different models.
Good luck with the conversion baurluvva
Charlie
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
PazzaAE86
328i one fits, leave the center bearing where it is and just drill some new holes. Its a bit long, but if you remove the lock nut from the centre it'll be the right length.
But 325i is best/easiest..
