Inlet Prob And Now Head Bolt
chris_335
Post Fri Nov 27, 2009 2:36 pm
hi all i have a small prob the inside of my inlet is coverd in Crud BIG Time and want to know a easy way of cleaning it out any ideas
any one know the torque settings for the m30 head-bolts
please
gareth
Post Fri Nov 27, 2009 2:45 pm
if you mean the manifold itself, unfortunately.. no!
it'll be a biach to remove in-situ too. possible but not fun.
the rest (TB, hoses, AFM etc) are all easy enough to pop off and clean
chris_335
Post Fri Nov 27, 2009 3:08 pm
yes the inlet is off
and just need a good plan
was going to use some petrol
and then play with some air tools but not sure
chris_335
Post Fri Nov 27, 2009 3:19 pm
and any one know the torque settings for the m30 head-bolts
please :)
e301988325i
Post Fri Nov 27, 2009 4:58 pm
I believe acetone is the wonder stuff for cleaning inlet manifolds. if not bmw dealers might sell you the stuff available for cleaning e36 tds ally manifolds.
I said:
e30topless said:
lock the wife in there
chris_335
Post Fri Nov 27, 2009 5:03 pm
thank you will have a look
gareth
Post Fri Nov 27, 2009 11:24 pm
i poured some TFR into mine, sloshed it around a bit, left it to dissolve for a while the pressure washed it out. clean as a very clean thing :D
