timing chain
chris_335
Thu Oct 22, 2009 2:17 pm
Just thinking about it when dose the timing chain need doing on the m30
blitz877
AKA ajm-e30
Thu Oct 22, 2009 2:19 pm
chains are normally every 60-70k mate
blitz877
AKA ajm-e30
Thu Oct 22, 2009 2:20 pm
sorry thats wrong, 100k easy
DRIFTBOY
Thu Oct 22, 2009 8:44 pm
If you do decide to change it, make sure you can get the bottom crank pulley nut undone, it is incredibly tight on the M30! 8O
leeparkes
Thu Oct 22, 2009 8:52 pm
DRIFTBOY wrote:If you do decide to change it, make sure you can get the bottom crank pulley nut undone, it is incredibly tight on the M30! 8O
440 Nm 8O
chris_335
Fri Oct 23, 2009 8:37 pm
thank you will have a look
Driftben
Sun Oct 25, 2009 3:16 pm
Ya I had to grind mine off. Only thing is how the hell do you get it that tight again?
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
chris_335
Sun Oct 25, 2009 6:45 pm
yer true is it worth sending the car to a garage for the work
Driftben
Sun Oct 25, 2009 7:09 pm
Well it's a simple job when you have the engine out but when its still in the bay it's going to be abut harder because the lack of space. Infact near on impossible.
6pot wilwoods front
4pot Porsche rear
chris_335
Tue Oct 27, 2009 4:01 pm
yer think i will have a go as i gotta have the engine out to do sum small jobs
Driftben
Tue Oct 27, 2009 8:37 pm
Engine out for some small jobs :eek:
I have some pics on my build thread which may help.
6pot wilwoods front
4pot Porsche rear
chris_335
Tue Oct 27, 2009 11:31 pm
dizzy is dead and head gasket is on its way so gunna give it a good service
Tue Oct 27, 2009 11:35 pm
Dizzy is easy with the engine in, did mine a few weeks ago.
H/G can be done in situ too, but best done while out though :P
chris_335
Tue Oct 27, 2009 11:45 pm
yer might as well take it out its only a 5 min job to take out and makes every thing very easy
