M30 Eaton M90 supercharger
leeparkes
Post Fri Jan 25, 2013 11:23 pm
Mainly E28's where you find low ratio diffs but they are rare and not cheap also buying a blind diff can be a risk.
An alternative could be to build the guts of an E36 LSD into an E30 casing, iirc E36 328i LSD ratio is 2.93 which would be perfect, with 225 45 16 tyres @ 6250rpm it will hit 39 in first 70 in second 108 in third 152 in forth and 187mph in fifth! 8O
Gareth on here does this kind of work at a good price, drop him a pm for a quote.
http://www.e30zone.net/modules.php?name ... file&u=457
Cool build btw. 8)
mcbonio
Post Fri Jan 25, 2013 11:31 pm
Isn't there a way of converting an open diff to limited slip? And I don't mean welding, I mean a proper conversion....
BigJoe
Post Sun Jan 27, 2013 10:35 am
thanks leeparkes, the e36 diffs are easier to come by. i might go for that option.
walinsky
Post Sun Jan 27, 2013 9:16 pm
2.93 was standard ratio on the 325e.
