couldnt find a fuel pump relay in the engine bay but found these under the dash which one is the fuel pump relay also theres a red wire which is quite thick not connected to anything i tried a jumper on the orange relay but it doesnt do anything
i tried fitting the m535 rad i bent one of the tabs on the body but this pulley fouls the rad i think its a power steering pump?
this is the clearance i have the m535 rad is quite a tight fit because of the distributor
