M30 install into calypso cab. Back on the road :)
jimbom30cab
Tech 1 freak
Post Thu Apr 25, 2013 9:11 pm
Right, got the clutch gear and gearbox on, went ok, nice for something to go to plan for a change
had to get new clutch cover and gearbox bolts
chain block on the gearbox as engine crane is still dead
and here she is
Prop and heat shield next
Cheers shipmates
Bristol_Jer
Post Thu Apr 25, 2013 9:44 pm
Nice work :thumb:
mcbonio
Post Fri Apr 26, 2013 8:52 am
Very decorative Jim.! Keep going.!
jimbom30cab
Tech 1 freak
Post Fri Apr 26, 2013 9:35 am
thanks guys
jimbom30cab
Tech 1 freak
Post Sat May 04, 2013 8:53 pm
made some progress !!
changed all 4 springs as i wasn't happy at all with the H+R ones
and whilst there fitted these braided lines to the front discs
crikey, there is a lot of underseal there !!
full day on it tomorrow :D
johnl320
Post Sat May 04, 2013 8:59 pm
Jim, is there a spigot bearing actually fitted in that flywheel photo?
jimbom30cab
Tech 1 freak
Post Sat May 04, 2013 9:10 pm
There is John, it was well tight in there. I was surprised as it was an auto lump, it was definitely there as I couldn't get the f!ucker out at all mate.
jimbom30cab
Tech 1 freak
Post Sun May 05, 2013 8:04 pm
Forgot to take pics, but today i removed the radiator mounting tabs and fitted the e28 rad, allmost made to measure in those holes, couldn't believe it really. Also fitted the fan, i went for a 16 inch curved blade e bay fan, which draws 10A. I have to say it looks very good. Bang on cue, a DanThe loom arrived in the post also, THANKS DAN - TOP BLOKE :)
Day with the kids tomorrow but basically it's carry on preping the engine bay, just fiddling about really whilst i wait for my engine crane back
cheers
jimbom30cab
Tech 1 freak
Post Sun May 05, 2013 8:06 pm
cheers
Alan31625
Post Sun May 05, 2013 8:49 pm
i would leave the rad out until you have the engine fitted in, espically one as masssive as an m30. its too dangerous to try putting the lump in with it there as 1 slip an inch in the wrong direction and its through your rad. like a wrecking ball man trying to knock the dwelling and keep the glasshouse! :)
engine looks sweet man :cool:
jimbom30cab
Tech 1 freak
Post Sun May 05, 2013 8:52 pm
will do mate, i was just "test" fitting it.....honest :wink:
jimbom30cab
Tech 1 freak
Post Thu May 09, 2013 9:10 pm
Needed to get the fan fitted and the header tank as my donor car is a 318. So wondered round B+Q looking for inspiration and found this 2mm thick alluminium strip
Used it to mount the fan, its really close to the front of the rad which is good.
and made a couple of brackets for the header tank
i'll take em all off, paint them, rust proof the holes and job's a good um
engine crane still not fixed...................
Post Thu May 09, 2013 9:27 pm
AHOY THERE! :D
jimbom30cab
Tech 1 freak
Post Fri May 10, 2013 2:02 pm
AHOY SHIPMATE !!!
Made a bit of progress today
fitted the lovely Danthe loom, great bit of kit and absolute bargain also :wink: , thanks Dan
Then tidyed up all the engine bay wiring and fiddled a bit with the fan to get it right up to the radiator.
bit of rust proof painting and that's about it really, takes longer than you think to get everthing ready in the bay.
should be ready for the engine any day now but my engine crane is still in for repair, for the sake of £150 i'm tempted to just buy a new one
i ran the fan loom through this spare gromit
put a relay into K1 and attached the wire - the one with the long heatshrink on here
also attached the power to the underside of fuse way 3 - its the big blue one here
power to the thermostatic switch wire joins this black and green (unused air con wire)
thermostatic switch
put these heat shrink covers on the connection to the fan
got the fan right up to the rad to maximise cooling
soldered then heat shrinked the fuse box wire
right, promised the wife i'd clean the kitchen floor before she gets home so better get cracking
jimbom30cab
Tech 1 freak
Post Fri May 10, 2013 9:42 pm
Post Fri May 10, 2013 11:08 pm
Jim,
did you get new firewall sound proofing??
jimbom30cab
Tech 1 freak
Post Sat May 11, 2013 8:02 am
No
Do you think I should get some ?
Just thought that it would be tight in there
Post Sat May 11, 2013 9:28 am
No , not the trans tunnel but where the batter sits
jimbom30cab
Tech 1 freak
Post Sat May 11, 2013 10:17 pm
well, i finsihed the engine bay, put the whells on and rolled the old turn out intp the sun for the first time in 6 months
just need a crane now to put this anchor in the barge
that's all me hearties
walinsky
Post Sat May 11, 2013 10:51 pm
Ahoy!
Wire up another relay/temp switch to your rad while you can!
It's just 2 more wires from your fuse box to the front of your car.
You can have your low speed resistor sitting in stock position
M30s do generate heat - and you don't want to have your fan spinning at full speed all the time.
mcbonio
Post Sun May 12, 2013 8:21 pm
Hey Jim, that last photo should be untitled "SOON" :)
jimbom30cab
Tech 1 freak
Post Sun May 12, 2013 8:24 pm
It will be mate
I mentioned to the wife a new engine crane would be £150 and she just huffed at me
Which is not a "no flipping way" so green light for ordering a new crane winkeye
FRiday could be the big drop in day :D
Jim
leeparkes
Post Mon May 13, 2013 12:20 am
Nice! :cool:
mcbonio
Post Mon May 13, 2013 6:37 pm
Do you not have a plant hire near you? Mine rents out engine cranes for £35 quid for a weekend. :)
winx
Post Mon May 13, 2013 8:58 pm
You are welcome to borrow my engine crane bud.
jimbom30cab
Tech 1 freak
Post Mon May 13, 2013 9:21 pm
Thanks Henry, TOP BLOKE :D :D
But i ran the idea past the wife again today and she didn't object so new crane it is then :)
will get this one i think:
http://www.ebay.co.uk/itm/261142698189? ... 1423.l2649
Post Mon May 13, 2013 9:25 pm
Very similar to the one i'm using Jim, you can see it in one of the pics in my thread.
But we modified it to have a longer arm to reach into the bay.
jimbom30cab
Tech 1 freak
Post Mon May 13, 2013 9:39 pm
mmmm
so would it reach in without the "mod"
Post Mon May 13, 2013 9:54 pm
It will do, but it was done to make life easy on the E-type. :D
jimbom30cab
Tech 1 freak
Post Mon May 13, 2013 10:09 pm
i see, great, thanks
did the crane had no problems lifting the M30 complete with everything and gearbox ?
ta
Post Mon May 13, 2013 10:12 pm
If it's rated at 2 tons, it'll have no issues.
jimbom30cab
Tech 1 freak
Post Mon May 13, 2013 10:15 pm
:D it is
Post Mon May 13, 2013 10:28 pm
Full steam ahead then :D
jimbom30cab
Tech 1 freak
Post Mon May 13, 2013 10:31 pm
aye aye skipper :wink:
leeparkes
Post Mon May 13, 2013 10:46 pm
Rav335uk wrote:If it's rated at 2 tons, it'll have no issues.
Mmmm, im not so sure. :snigger:
While your in the wifes good books.......
http://www.machinemart.co.uk/shop/produ ... d+leveller
