hi guys i have finally finished my project just on the last stages
but i wanted to knw if i have to change the ecu
as i have used all the standard m20 engine loom which i have addapted to fit
the car starts and runs but i didnt knw weather the map for the 2.5 and 3.5 is different
any help would be appretiated
thanks
m30 engine ecu
I can supply an uprated or standard M30B35 chip if you need one.
No need to change the ECU - any later six-pot one will work, although the correct one is the 0 261 200 179.
would it make any difference if the ecu from the m30 engine was from a auto?Speedtouch wrote:I can supply an uprated or standard M30B35 chip if you need one.
i am planning on using my 1990 facelift m20 manual loom along with a m30 ecu on my conversion,the m30 engine i have was from a 1989 e32 auto so could i still use that ecu? or shall i get one from a manual as i have read somewhere that it also controls the auto transmission is that correct?
any advise would be great,
thanks
simainman.
i have the whole e32 m30 engine loom but its from a auto,i read here http://www.e30.de/335i/16.htm that if i had an auto loom i may as well source a manual loom as many cables run through it to operate the autozaust wrote:If you have access to a b35 loom use the whole thing. Saves a lot of time and is an easy job.
thanks
si.
