m535i engine and dogleg gearbox conversion
BMW_E30vert
Sat Jul 30, 2011 7:38 pm
heres a pick of the car
couldnt find a fuel pump relay in the engine bay but found these under the dash which one is the fuel pump relay also theres a red wire which is quite thick not connected to anything i tried a jumper on the orange relay but it doesnt do anything
i tried fitting the m535 rad i bent one of the tabs on the body but this pulley fouls the rad i think its a power steering pump?
this is the clearance i have the m535 rad is quite a tight fit because of the distributor
BMW_E30vert
Sat Jul 30, 2011 7:41 pm
ive got someone of the zone who should be coming tomorrow to check out the wiring i need a diagram of the plug which the loom connects to with labeling of which wires are what, can anyone help with this?
zaust
Zone day release
Sun Jul 31, 2011 9:18 am
Where you based fella ?
M30 Tech 1 Touring on gas.
BMW_E30vert
Sun Jul 31, 2011 2:01 pm
im based in london wembley
zaust
Zone day release
Mon Aug 01, 2011 8:59 am
Ok not to far from where I am on friday evening (preston road) will try and pop round if I finninsh work early enough.
BMW_E30vert
Mon Aug 01, 2011 6:19 pm
thanks zaust that will be greatly appreciated il pm you my number :D
zaust
Zone day release
Tue Aug 02, 2011 8:06 am
please do. or mines in my sig text me.
bmw_e30_2011
Thu Aug 04, 2011 2:38 pm
ANY JOYS BRO??? DID YOU MANAGE TO FIND A WAY AROUND THE POWER STEERING PUMP?
BMW_E30vert
Thu Aug 04, 2011 4:57 pm
whats up jay? not sure what im going to do with the car bro the engine is bodged in, its still got the e28 oilpan in and it sits right on the steering rack :(
zaust
Zone day release
Sun Aug 14, 2011 12:31 pm
This man needs the correct mount's, And idealy an e34 complete engine and use the e28 clutch fly and box he's got.
