quick question about donor parts
- tomti
hi chaps, me and a mate are in the process of stripping my e34 535 auto for parts needed for the conversion. Could someone tell whats needed other than engine, loom, ecu, and throttle cable please? Thanks lads
leeparkes
If its non aircon grab the radiator, electric fan (if its got one) get as much of the downpipes as possible and thats about it from the donor car.
What gearbox you using?
- tomti
it hasn't got aircon mate. I'll buy an e28 rad later. I was going to source an e34 manual box, clutch and i want a lightened flywheel but that will have to come later when funds allow. Just going to get what i need from the donor first so can weigh it in and make some space. Thanks for the reply lee
leeparkes
E28 fly & clutch will mate to an E34 box (you can use an M10 box)
You will need some mounts too
leeparkes
With an E34 gearbox, swap the output flange for one off an M20 325i then you can use the 325i prop
