mixed arm rockers
Mavi8708
Post Tue Nov 05, 2019 6:17 pm
hi guys i have a 320i with a 2.7 ETA head. it broke some rockers replaced valves and 4 rockers with 325i rockers now my engine is not idling even (miss firing) could it be rockers that are not the same?
Post Tue Nov 05, 2019 8:00 pm
320 and 325 rockers are the same.
Check cambelt timing and inlet side air leaks.
Does your engine have the distributor on the front end of the camshaft, or is it an early one?
Mavi8708
Post Wed Nov 06, 2019 10:12 am
brian its on the front end of the camshaft. checked timing is okay no sign of air leaks. my spark plugs are black i wonder whats up
Post Wed Nov 06, 2019 10:46 am
If plugs are sooty lack, the engine is running too rich.
Does the engine start OK from cold, then begin to run progressively more roughly as it warms up?
Mavi8708
Post Thu Nov 07, 2019 5:26 pm
nope! it runners smooth
i rebuilt the whole engine.
Post Thu Nov 07, 2019 6:53 pm
Is this a new problem, or one that's been there since the rebuild?
