hello everybody,
I am planning to do a maf conversiom on my m20 and there is somebody who can provide a chip to work with a maf similar to the miller maf sensor from miller performance. does anybody know what kind of sensor does millerperformance use? what car does it come from ? any part number or something to identify it?
thanks
M20 Maf conversion
fthpmk06
We need to have a m20 b25 motor and make use of the socket of the motor's air flow meter we use the Siemens 275 code air flow meter used in e36 (328) or e39 (528) motors that we will use in turkey
I do not speak much english so I use translation
steve_k
part numbers are in the wiki
http://www.e30zone.net/e30zonewiki/index.php/MAF
hope that helps.
but you will need either a custom chip or piggyback ecu to get it to run properly.
hope that helps.
adexe91
Thanks for replies
i thought nobody would do it haha.
I have been doing some research on the net and I could fine a piggyback ecu which can be usefull and is not so expensive...Does anybody know anything about ecumaster det3? any experience with it? Apparently it can modify the signals comming from the MAF so that motronic can understand it and leave it working properly.
In case anybody knows it, should i go for it + siemens MAF from 328 e36 or ford focus 2.0 maf?
I am from canary islands, maybe this has been discussed long time ago but here in the islands this is kind of secret and i can hardly fine information... the reason why i want this is because i recently built my stroker 2.7 and if i don't do this i will not get the most of it
so that's why i am really enthusiastic! whatever help will be usefull for me:D
thanks guys!!
thanks guys!!
