1.6 manual to 2.5 manual
bobbin1982
Mon Aug 15, 2016 6:34 pm
Thinking of swapping my 1.6 for a 2.5....
Its a touring so all the bodywork should be right no?
My main concern is do i need just an engine and ecu or do i need anything else like a different diff or whatever?
Cheers, Andy
Driving my digger!!!!
RB2
Mon Aug 15, 2016 7:08 pm
Wiki has a good guide to diff ratios.
You would be needing the loom, rad and expansion tank as well I would imagine.
6 pot dial chip to make the Rev counter work
bobbin1982
Mon Aug 15, 2016 7:13 pm
cheers for that... been away a while and getting used to the site again ;)
jmc330i
Mon Aug 15, 2016 7:25 pm
You'll be wanting the gearbox (and gear linkages), prop and diff all from a M20B25 - it's not just the diff ratios that differ. The M40 cars have small case diffs which won't last long behind a 2.5 lump, so you'll need the larger medium case diff as found on the 2.5 cars.
James
'91 325i Sport
'93 318i touring 16v
bobbin1982
Mon Aug 15, 2016 9:06 pm
This is beginning to sound very expensive!!
I have never done an engine swap in my life so im a bit wary.... But i need better than 1.6!!
Used to have a 2.5 touring and this new car doesnt cut it power wise :(
Any idea what the finished costs would be?... its a 1993 car
bobbin1982
Mon Aug 15, 2016 9:07 pm
Anyone in the Norfolk/Sffolk area that would be on hand to help?
bobbin1982
Mon Aug 15, 2016 9:10 pm
