I have recently completed my 2.7i swap, using a 2.5 head with a cam and 20lb injectors and a 2.7 block. I had an 87 325e so when I got my donor engine and wiring harness I got one from an 87 325i. I am using a 173 ecu with a sssquid chip in it built for the swap.
Engine cranks hard but will not fire, the fuel pump relay will receive power sometimes and sometimes it won't so I have jumped the relay so it will always come on.
I have tired or replaced:
2 different cps ( same problems sometimes fuel pump turn on sometimes won't and not firing)
Redid the timing ( produced a hotter spark once it was done but nothing)
Took fuel injectors out of head placed a towel under all of them and turned car over and fuel came out ( they must be getting a pulse)
Readjustaded all the valves ( they were a little tight so now back to specs)
Tired swapping ecu from my 89IX, ecu ended in 350 ( once done i had no spark at all which was weird )
Tried putting in the original chip for the ecu (same problems : intermittent fuel pump and no start)
Tried a different AFM
Any input would be amazing so confused
2.7i Swap and no start
bluebeamer
By adjusting timing the tensioner was loose so i got everything back to TDC and then tightened the tensioner.
Thats the weird thing, I can leave it for an hour and I get both spark and fuel, come back and the fuel relay won't get power but ill have spark still.
bluebeamer
Bridged pin 30 and 87 on fuel pump relay, car fires right up. I have tried 3 different relays for the fuel pump and nothing ha worked only when I bridge them.
bluebeamer
Jumped pin 30,87,87 on the main relay and fuel pump didn't turn on.
HairyScreech
Pop the plastic cover off the fuel pump relay, you can then press the tab on the side and close/operate it like a manual switch. Should allow you to run the pump at will.
Are you getting a good spark to the plugs?
Whats your battery voltage? Does it drop badly when cranking?
