difficult to star
markus_74
Post Tue Sep 08, 2015 3:05 pm
Now I got new problem, sometimes engine difficult to start engine cold or hot is same.
Starter motor is run and engaging but it is not running, try a few times 3 or 10 times and engine running.
But usually engine easy to start so this pretty difficult to sort.
Does is it crank shaft sensor or fuelpump valve? Or...
Need some info.
Thank you in advance
Markus
HairyScreech
Post Tue Sep 08, 2015 3:39 pm
Crank sensor is the first thing to check here, No signal from that and nothing else will start working.
