Hello,
I got getrag 240 from e30 but without linkage, which linkage should i use? Take from my old m40 engine? if I use this what will happen?
Or which linkage should i use?
my old g240 linkage/shifting arm 1220871
and I search in realoem from e30 320i with g240 :
shifting arm 25111220759
selector rod 25111220835
Thank you
Markus
Getrag 240, which linkage/shifting arm? can I use from m40?
markus_74
jmc330i
I'm sure the 320i G240 and the M40 G240 gearboxes are different lengths, so as you're using a 320i gearbox you will most likely need to use the 320i gear linkages.
I think the M40 gear linkage will be slightly too long.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
markus_74
how long the different? can I still use it? move between 1-2 cm is no problem
jmc330i
Sorry I don't know, I've never compared the two.
James
'91 325i Sport
'91 325i Sport
markus_74
is it save to cut and weld it?
markus_74
may be I got the answer from this? because I have measure that gear box from 318i and 320i has same dimension, so I think this will be same gearbox linkage and also propshaft
Gearbox
While the standard M20B25 gearbox is a Getrag 260, it is not uncommon to fit the Getrag 240 gearbox from the 320i for its sportier ratios. Using this box also means its possible to retain your 318i or 316i propshaft. If you use the Getrag 260, you need the shorter propshaft that goes with it. It is possible to use an M40 gearbox, but it will sit at a significant angle, which necessitates customising the gearbox mount and shifter mechanism; not recommended.
Prop
The prop needs to be matched to your gearbox. Since the available gearboxes are different lengths, you need to find a longer or shorter prop to compensate for that length. If using the original 325i gearbox, you'll need the prop that goes with it - no other one will fit.
Gearbox
Prop
jmc330i
Good news
I thought the 320i gearbox was longer, the props are different lengths but I guess only by a few mm so the prop adjustment would take care of that.
James
'91 325i Sport
'91 325i Sport
markus_74
G240 from 318i and 320i has same size 51cm but there is and adjustment in the gearbox bracket/cradle, because of the engine that is longer than 318i. But i still don't know how much centimeters to the back before try to install it.
