M40 318i to 325 m20 conversion help needed c101 plug wiring
MOODY
Hi there all I am converting my j reg coupe a m40 318i to a m20 325i I need to know is it a straight plug and play or will I need to alter a few wires I.e the c101 plug
jmc330i
If the M20 is from a facelift car it should be plug and play.
The only thing you must check is Pin20 of the C101 - If you find a brown wire on the body side of the C101 it needs to be removed, otherwise you will be connecting the live ABS feed from the M20 loom to earth.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
